Issues with Motion 2 crashing
COW Forums : Apple Motion
joonofilms
on Jul 26, 2007 at 10:18:15 pm
So I have a problem with Motion 2 crashing on me. It's never done it before and I'm pressed for time. Though it should be noted that I only run it on a G4 powerbook with 2 gigs of ram. I know that my lame computer is no doubt the primary reason for the program crashing; however as I said, "it's never done this before." I'm fine with lengthy render times etc., I just want it to work a little bit. Does anyone out there have any suggestions on what might prove the best fix? Thanks.
NSHEX1
Re: Issues with Motion 2 crashing
on Aug 8, 2007 at 5:12:20 pm
had the same problem.
lower res for work,save before render, and un-tick the 'put hard drive to sleep' in energy pref.
also, i put my MBP directly on the Air conditioner outlet. ran 46c while render!
The cup is half full and my shirt is half wet
