Repeatable motions in Motion
COW Forums : Apple Motion
chlucasj
on Jul 26, 2007 at 4:11:54 pm
I am working on an animation sequence and I am trying to find a way to basically cut and paste a sequence in a layer so that I can repeat the same motion without having to recreate it by hand.
Specifically I am changing the shape of the object (and letting Motion create the transition) but I want some of the shapes to be repeatable.
Arniepix
Re: Repeatable motions in Motion
on Jul 26, 2007 at 6:17:39 pm
Simply put all of the objects that you want to apply the motion to in 1 layer, & apply the move to the layer.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Ben Scott
on Aug 5, 2007 at 10:35:45 am
you need to be using the after last keyframe command down in the keyframe editor and set to repeat
sometimes behaviours can be used to create these types of effects e.g. an oscilattor
