Next problem -- Has anyone gotten Master Templates to work?
COW Forums : Apple Motion
Wayne Franklin
on Jul 20, 2007 at 5:56:44 pm
I searched the forums, and this topic doesn't seem to have come up, yet. Maybe I'll check over in FCP.
Anyway, I did everything as instructed in both the Motion manual and the FCP manual to create a Motion master template, edit it into my FCP sequence and then open the Controls tab in the Viewer. I drag my clip, with ins and outs set, to the clip well in the Viewer. A thumbnail shows up in the well and the source file is listed properly, but nothing changes in the actual sequence. In the Canvas, I still see the drop zone icon where the new clip should be.
Are there workarounds or known issues here?
The cheese stands alone.
Noah Kadner
Re: Next problem -- Has anyone gotten Master Templates to work?
on Jul 20, 2007 at 6:23:36 pm
What sort of clip- remember it should be standard QT media preferably trimmed to exactly what you want to use.
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
Wayne Franklin
on Jul 20, 2007 at 6:48:13 pm
It's an HDV 1080i60 project, as are all of the clips. All footage was loaded using the HDV capture settings in FCP. I am using a subclip. I tried making it a master clip, but that didn't work either.
After your message, I thought it might be an HDV issue. So I exported a reference movie of the same clip from FCP, imported it into Motion, dropped it into the appropriate drop zone, and VOILA! It worked as expected.
I just want this thing to work as advertised. I need to be able to easily customize these animations within FCP for efficiency's sake. (Of course, how efficient is spending all my time trying to solve workflow bugs?) Otherwise, I never would have bothered with Motion and just knocked it out in AE.
