working resolution vs. finished resolution
COW Forums : Apple Motion
oellen
on Jul 5, 2007 at 9:30:47 pm
I was wondering if I can work in a low resolution then when I'm done render my file in a high resolution. Here is what I'm trying to do. I am working on a short animated film using stills that are prepared in Photoshop. I want my final output to be to 35 mm film and HD video. All my still images are 1920 x 1080. I'm working in Motion 3 on a MacBook Pro. I have set the file up at 1080i@24 fps. But if I do anything at all complex, like use the replicator, the computer just crawls at about 2 fps. So what I was wondering is if I could initally work at something like 480 x 270 while doing the rough edit and then change it later once I'm finished experimenting and I'm ready to send it to FCP. Can this work? Thanks for the help. It sure would be nice to speed this process up a little without buying a new computer.
Noah Kadner
Re: working resolution vs. finished resolution
on Jul 5, 2007 at 9:58:54 pm
Sure set the playback resolution to half or quarter- that's just above the canvas, between color space and zoom setting.
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
