stairstepping on my Logo
COW Forums : Apple Motion
sozoavg
on Jul 5, 2007 at 8:04:20 pm
I have a clients logo and made it in Photoshop CS. Ive got it at 300 dpi 72 dpi I placed it in a widescreen template in PS and when I get it into Motion it looks like dog squeeze on the edges. Whats the best remedy for this? thanks so much!!
Noah Kadner
Re: stairstepping on my Logo
on Jul 5, 2007 at 10:04:50 pm
Can you post a still- so we know how it looks?
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
Winston A. Cely
on Jul 6, 2007 at 11:46:13 am
I'm having the same trouble. Here's a look at mine:
http://i201.photobucket.com/albums/aa50/handthatfeeds/Route66.jpg
This is at HD 720P project setting.
Winston A. Cely
Editor/Owner | Della St. Media, LLC
"If God could do the tricks we can do, He'd be a happy Man." - Peter O'Toole - "The Stuntman"
Mac Pro 3GHz Dual-Core Intel Xeon
4 GB RAM | Final Cut Studio 5.1.4 | Aja Kona LHe
sozoavg
on Jul 6, 2007 at 1:21:21 pm
http://s204.photobucket.com/albums/bb102/sozoavg/
sozoavg
on Jul 6, 2007 at 1:24:05 pm
this should be it
photobucket.com/albums/bb102/sozoavg/YamahaStill.jpg
Noah Kadner
on Jul 6, 2007 at 4:05:42 pm
I'd try to apply the deinterlace or anti-aliasing filter.
-Noah
sozoavg
on Jul 6, 2007 at 5:51:28 pm
Nope thats no good...kinda looks worse. Thanks anyway.
Noah Kadner
on Jul 6, 2007 at 6:26:06 pm
Also resizing it outside of FCP to fit your frame in FCP will result in better quality.
Noah
sozoavg
on Jul 6, 2007 at 6:29:31 pm
It looks okay in FCP its Motion where its bad. Thanks for your input.
Arniepix
on Jul 6, 2007 at 9:14:03 pm
Try about a .5 gaussan blur on your Route 66 sign.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Winston A. Cely
on Jul 7, 2007 at 8:13:24 pm
Thanks for the tip. I actually had to add a 3 to 4 point G.Blur to it to get rid of the lines. It's unfortunate because it does soften it just a bit more than I'd like. As usual I'll just make a version that's only slightly bigger than my frame size. (The picture you're looking at is scaled down to 24% from it's actual size!)
Winston A. Cely
Santiago Gutierrez
on Jul 8, 2007 at 9:22:54 pm
Switching your Render Quality to Best from Normal will get rid of the aliased edges. This can be found under the "View" menu. Of course the render times go way up, but the tradeoff is that graphics are properly rendered. I was dealing with this all last week on logos. The reason it looks good in FCP is that FCP defaults to the Best rendering quality by default, you can check this in your sequence settings under 'Render Control' in FCP 6.
Hope that helps,
Santiago
Winston A. Cely
on Jul 9, 2007 at 6:09:10 pm
Thanks! That did it!
Winston A. Cely
