creating presets from filter keyframe settings
COW Forums : Apple Motion
lmenstudio
on Jun 21, 2007 at 3:26:38 pm
How do I create a preset from filter keyframe settings.
In other words, I use a filter, I set some keyframes, now I want to make a preset that I can use later.
Trace Burroughs
Tracy Burroughs
Little Men Entertainment
little-men.com/index2.html
specialcase
Re: creating presets from filter keyframe settings
on Jun 22, 2007 at 6:11:50 pm
Heya,
Everything and anything in Motion can be made into a preset, from the single parameter to an entire project. For example, if you've keyframed the Midtone Blue value in a Color Balance filter, you can make a preset of just the Midtone Blue parameter, or you could make a preset of the entire filter. Just drag the parameter (or entire filter, depending on what you want) to the Library, and Motion will make a preset.
