Motion 3 subpixel rendering
COW Forums : Apple Motion
Paul Ingvarsson
on Jun 15, 2007 at 9:47:36 am
Hello,
I'm doing some very simple text floats across screen with Motion 3. The movements are created using the throw behavior and the edges of the text are 'creeping'. I recognise this from operating DS Nitris and needing to use subpixel rendering. Is this something Motion can do? or am I better off making a double size comp and scaling down afterwards to get better motion on my edges?
Many thanks,
Paul
Noah Kadner
Re: Motion 3 subpixel rendering
on Jun 15, 2007 at 5:17:09 pm
Are you looking at the final output with all quality settings to high or a lower res proxy preview?
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
Paul Ingvarsson
on Jun 16, 2007 at 7:08:50 am
No, I've double checkd al my output settings when I choose to export the project to an animation quicktime. 32 bit float, Full res and best quality render. I don't have motion blur switched on because the text is moving very slowly and adds loads to the rendering time.
Paul
specialcase
on Jun 16, 2007 at 1:19:40 pm
Heya,
Motion blur definitely adds to the render time, but so does using 32-bit float. Are you doing any particular operations that require float? It adds a lot of overhead to the processing, and doesn't often make a difference.
