reverse an object
COW Forums : Apple Motion
Wayne K 123.
reverse an object
on Jun 7, 2007 at 11:10:26 am
I created a rectangle object in Motion 2, and keyframed a special
path from left to right.
Now I want to have a duplicate of that rectangle to move in the exact
opposite direction at the exact speed.
Is there a way to reverse an object/path in Motion 2?
Thanks in advance,
Wayne
specialcase
Re: reverse an object
on Jun 7, 2007 at 2:56:36 pm
You sure can, through the cunning use of the diabolically-named Reverse behavior ;)
Motion has a special class of behaviors called parameter behaviors. Instead of being applied to the whole object, they are applied to a specific parameter. For example, you might apply Randomize to an object's Opacity to make it flicker.
In your case, just apply a Reverse behavior to the Position parameter of your animated object. Right-click on the "Position" parameter label in the Inspector and pick Reverse from the menu.
Wayne K 123.
on Jun 7, 2007 at 9:16:23 pm
Specialcase,
Thanks so much -- that's why you get paid the big bucks ;)
All the best,
Wayne
