Keying plugin for motion 3
COW Forums : Apple Motion
Zach Smith
on May 24, 2007 at 12:30:21 am
I have a project that we started to work on in motion 2 on a non intel machine. We used a plugin from DV Garage called DV Matte Pro, this plugin is not available for intel machines. The company has another plugin called DV Matte Blast for motion 2 which is universal but does not appear to work in motion 3. Does anybody know of a plugin that is comparable to this one that works in motion 3? This was the only plugin that I know of where you could have two different shades of green and it would average the two or something like that. All stock plugins and even third party plugins I have found will not key this footage correctly. HELP
Noah Kadner
Re: Keying plugin for motion 3
on May 24, 2007 at 3:10:16 am
I'd say key it in FCP with the DV Garage plugin or the Noise Industries one. I'm sure the one you use now will ultimately be updated for Motion 3 if feasible.
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
specialcase
on May 24, 2007 at 1:28:11 pm
Heya,
I'm using dvMatte Blast in Motion 3, right now. What problem did you experience when trying it in version 3?
TJack4825
on May 27, 2007 at 5:06:41 pm
For me, when I choose to view the foreground in the DVMatte Blast plugin, the foreground layer completely disappears on me. I downloaded the demo as well to check and it does the same thing as my retail version does.
I am using Motion 3 and a 15' 2.33 Macbook Pro
RodereckJaynes
on May 24, 2007 at 6:09:37 pm
Yes, I seem to be having the same problem. As soon as I apply the effect, the program immediately crashes...
specialcase
on May 25, 2007 at 1:11:57 am
Are you running the Universal Binary (Intel & PPC-friendly) version?
rodereckjaynes
on May 25, 2007 at 1:33:12 am
Yes,
As a matter of fact, I tried it on my macbook pro and it worked, however, my main system is PPC.
I think the UB side that works with the PPC is still the old version mashed with the upgrade.
Very sad, my workaround is that I am keying on the macbook to animation alpha movies, then dragging them back to the tower. It's a huge pain.
Can prores include an alpha channel?
