Motion Export ?
COW Forums : Apple Motion
staticthrustfilms
Motion Export ?
on May 24, 2007 at 12:10:17 am
I would like to know when exporting a motion project as a quicktime movie does it automatically fill the background with black ? I made a motion title on a transparent layer (i think) but when importing it to FCP the background is black and not transparent. Is it possible to export just the title without the black ?
Noah Kadner
Re: Motion Export ?
on May 24, 2007 at 3:14:00 am
There's a preference to set background opacity, and it will only export with formats that contain an alpha channel such as Animation codec or a Photoshop image sequence.
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
staticthrustfilms
Re: Motion Export ?
on May 24, 2007 at 3:47:04 pm
Thanks Noah, I finally figured it out. I just added a white Alpha channel to one of the layers and it works. I am having an issue with importing the Motion file into FCP with audio. For some reason the sound does not come with it. Do you have any suggestions
Noah Kadner
Re: Motion Export ?
on May 24, 2007 at 4:18:03 pm
Are you sure you're sending it from Motion- there's options to save without audio.
Noah
staticthrustfilms
Re: Motion Export ?
on May 24, 2007 at 4:25:33 pm
I exported once to QT and the audio was there. I will check the settings once more.
staticthrustfilms
Re: Motion Export ?
on May 24, 2007 at 4:31:01 pm
I don't seem to see where i can change the save options ?
Robert Hutchings
Re: Motion Export ?
on May 25, 2007 at 5:56:30 pm
OK I realize I
Robert Hutchings
Re: Motion Export ?
on May 25, 2007 at 9:07:18 pm
OK just discovered the reason for the render time discrepancy. Coming out of the FCP and sending the clip to Motion. The motion project opens up defaulted to 8 bit in the project Properties. Command-J. Set bit depth to 16 bit and the render times out of Motion match the ProRes (HQ) render times on the FCP time line.
