Canvas settings 16x9
COW Forums : Apple Motion
Norman44T
on May 14, 2007 at 3:53:32 am
I am attempting to create some opening credits with 16x9 screen size to match the format of DV 16x9 from a Sony HDV camera.
How do I set Motion to have a 16x9 canvas size. Every setting combination that I have tried only produces a regular 4x3 size.
Can anyone provide some guidance as to how I can get the desired setting?
Thank you
Peter Wiggins
Re: Canvas settings 16x9
on May 14, 2007 at 8:06:14 pm
Norman,
have you tried 'Correct for aspect ratio' in the view menu?
AppleJ brings up the project properties
Peter
Norman44T
on May 16, 2007 at 3:46:01 am
Thank you for the lead.
It was checked. After unchecking, the image outline and contents all
expanded to the desired 16x9.
I did not think the solution would be so easy.
My other conclusion is that the final desired output size format, 4x3 or 16x9, needs to be set when the motion project is exported out of Motion.
Norman
