unexpected quit..
COW Forums : Apple Motion
stefan kroesbacher
unexpected quit..
on May 11, 2007 at 6:55:26 am
Hi all,
i just started working with motion 2.
i made a project with about 25000frames.
strengely, motion quits and compressor fails
when i export/render at the last 2 percent.
even with a still image sequence!!!!
but if i split the render into 2 pieces,
everything's fine.....
so: is there any render limit i should know of??
thanx
stefan
motion2, 8core, x1900, proappsupport 4.0
Ben Insler
Re: unexpected quit..
on May 11, 2007 at 4:01:43 pm
What resolution are you exporting to? And are you exporting a still image sequence, or have you imported one (or both)?
I've been having Motion crash almost predictably doing simple composites and fades while rendering out to 1920x1080 animation.
-Ben
stefan kroesbacher
on May 18, 2007 at 7:41:19 am
well the reason was: GLOW
i applied the effect to a video layer that scaled from full screen to smaller and back...
result was: corrupted frames in the video while scaling, and the crash..
GLOW removed, everythings fine....
hmmm
