B spline mask!
COW Forums : Apple Motion
Tarik M. Sykes
B spline mask!
on Apr 24, 2007 at 4:31:25 pm
I have a rotating globe. It is a QT mov.! I masked it off and need to export the globe. I tried this and I have a blk. background not a trans. back.What am I doin wrong? Thanks!!!
John Czerwinski
Re: B spline mask!
on Apr 24, 2007 at 5:48:48 pm
File - export
under the Video/Audio tab
change compressor pull down to animation
under the Output tab
if the, "current project and canvas settings" is checked, uncheck it
and make sure Color pulltab has color + alpha
export file
Good Luck
John
tarik m. sykes
Re: B spline mask!
on Apr 24, 2007 at 6:36:10 pm
it still has the color back ground. i want it to have no background. It want it to be transparent!! Thank you...
tarik m. sykes
Trans is on in preview
on Apr 24, 2007 at 6:45:59 pm
Transparent is workin in the preview next to canvas. But when I exort it, it has the blk. behind it not trans!!!!!!!
John Czerwinski
Re: Trans is on in preview
on Apr 24, 2007 at 7:59:06 pm
How about this...File - Export - then under the export preset pull down, choose lossless + alpha movie.
BTW what program are you importing this file into?
Hopefully this will work
Good luck
John
Tarik M. Sykes
on Apr 24, 2007 at 10:16:34 pm
that didn't make the globe export with a transparent backgrnd! This is crazy I can't figure it out!! I need to count to ten. I'm just goin to turn into a flash video and put on a web site. Once I mask it off it looks like it is right and then when i ex it isn't right. What do I do....it was a istock globe video and then put into motion 2 for maskin!Thanks
Tarik M. Sykes
I got it!!!!!
on Apr 25, 2007 at 4:13:36 pm
Not sure I was watchin a trainin vid on motion 2 and tried it all over and it worked.
John Czerwinski
Re: I got it!!!!!
on Apr 25, 2007 at 4:40:38 pm
Great. how did you export the file?
Tarik M. Sykes
Re: I got it!!!!!
on Apr 25, 2007 at 6:37:53 pm
the trainin vid was sayin what u said but I had the transparent on not the color on the canvas. So it had no alpha to take out. So I set it bak to color and it worked. I think him explaining made me put it back to color!Thanks!!!!!
