Layer disappeared
COW Forums : Apple Motion
Whirler
Layer disappeared
on Mar 3, 2007 at 9:10:12 am
I'm sure there is a simple solution for this but I cant seem to figure it out.. I've had an entire layer become invisible on the canvas. The canvas settings look normal and all the right boxes are ticked in the project pane. I can see the guides in the canvas if I highlight the sublayers but I cant see the media.
Thanks in adavance
Jim Kanter
Re: Layer disappeared
on Mar 7, 2007 at 5:12:40 pm
Check your parameter inspector settings such as scale, opacity, composite mode, position, etc.
Check the media tab to make sure the clip is still listed and make sure the clip is actually where it should be in Finder.
Make sure that the clip duration bar in the timeline indicates that the clip should be visible.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
