Groups of animation frames to QT via Motion
COW Forums : Apple Motion
Godfrey Pye
on Mar 2, 2007 at 6:49:17 pm
I am editing an animated promo, getting pictures from the animation house as groups of consecutive frames.
They are TIFF
Arniepix
Re: Groups of animation frames to QT via Motion
on Mar 5, 2007 at 12:09:22 am
You can actually do this in Quicktime directly, without using Motion at all.
In QT Pro, simply go to File>Open Image Sequence, navigate to the folder that has the image sequence in it, select the 1st frame & click the 'Open' button. Then you can export the image sequence directly into the same codec that your editor is using.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Godfrey Pye
on Mar 5, 2007 at 12:41:05 am
Thank you Slave, I've actually done that but I thought the Motion idea was somehow ' cooler' - it's just that I am uncertain about my own ignarance when setting the parameters. Maybe I'll go back to the way you suggest.
Godfrey
