Generate water effect
COW Forums : Apple Motion
Bryanman
on Feb 28, 2007 at 5:43:43 pm
I need to create a shot where a fire hose appears in the frame and then a stream of water (with alot of force) comes out of the hose. Any ideas on a simple way to simulate the water stream (because of limitations I need to do this in post).
Thanks in advance
John Czerwinski
Re: Generate water effect
on Mar 8, 2007 at 6:56:35 pm
Try "Spout" under the Particle Emitter. Bring up the Birth Rate, Speed & Speed Range.
Good Luck
John
