Motion won't Save or Export!
COW Forums : Apple Motion
iamsoclever
on Feb 13, 2007 at 5:18:14 am
Help! I'm running Motion 2.1.2 on a MacBook Pro. I am unable to "Save," "Save As" or "Export" my projects. No dialogue appears at all. Tried reinstalling, also tried deleting "com.apple.motion.plist" Any ideas? Thx!
2007-02-13 00:00:14.227 Motion[456] Can't open input server /Library/InputManagers/Smart Crash Reports.bundle
2007-02-13 00:00:43.703 Motion[456] *** -[NSNavSegmentSwitchControl cellAtRow:column:]: selector not recognized [self = 0xa55f310]
2007-02-13 00:00:43.783 Motion[456] *** -[NSNavSegmentSwitchControl cellAtRow:column:]: selector not recognized [self = 0xa55f310]
grafxflow
Re: Motion won't Save or Export!
on Feb 13, 2007 at 8:53:42 pm
Try running 'disk utility' and doing a 'repair disk permissions'.
grafxflow
grafx that flow!
iamsoclever
on Feb 13, 2007 at 10:42:18 pm
Update: I ran disk utility and repaired permissions - no luck. Next, I created a new user "TestUser" and logged in. Motion DID work under the new user account. That narrows it down a bit, the framework is ok. Unfortunately, I can't find any uninstall documentation for Motion. If I can just uninstall and reinstall I think it will fix the problem.
grafxflow
on Feb 13, 2007 at 11:22:36 pm
Try this,
delete
motion app folder
library/receipts/motion.pkg (this may differ dependent on version of motion).
then reinstall.
grafxflow
grafx that flow!
grafxflow
on Feb 13, 2007 at 11:23:06 pm
Try this,
delete
motion app folder
then reinstall.
grafxflow
grafx that flow!
grafxflow
on Feb 13, 2007 at 11:23:28 pm
Try this,
delete
motion app folder
then reinstall.
grafxflow
grafx that flow!
grafxflow
on Feb 13, 2007 at 11:25:54 pm
I Apologies,
My connection must be causing problems!!!
OOPS!!
grafxflow
grafx that flow!
iamsoclever
on Feb 14, 2007 at 12:31:21 am
Thank you, Grafxflow! After the reinstall it worked just fine. Much appreciated.
Burt Brown
on Feb 14, 2007 at 2:24:07 am
Grafxflow:
Thanks! I'll give that a try the first chance I get.
Burt
