no background
COW Forums : Apple Motion
sjon11
no background
on Jan 27, 2007 at 12:24:26 pm
I want to animate a type effect in Motion and then export to AVID. But I only need the letters and not the background in AVID. In other words:
the letters should lay over the video. I tried different things without success. What should I do?
walter biscardi
Re: no background
on Jan 27, 2007 at 1:03:42 pm
That's called an Alpha Channel. Export using Lossless+Alpha
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
sjon11
Re: no background
on Jan 27, 2007 at 8:07:58 pm
Where do I find that....? It's not in the export-settings....?
sjon11
Re: no background
on Jan 27, 2007 at 10:01:28 pm
In other words: I just wanna add an alpha channel so that AVID can read it....searched for it, couldn't find it....
sjon11
Re: no background
on Jan 28, 2007 at 8:52:45 am
I'm on motion 1 and the last hours i tried again everything. For ex: I put the background color (in property setting) on 0 %. I found the export setting lossless movie + tried exporting alpha and/or color and alpha.
In motion I get the checkerboardbackground (which means transparancy I guess)....but all I see in AVID is a background and the text doesn't lie over the AVID-background. I'm desperate. It shouldn's be so difficult to export ONLY text, in my opinion. But where's the secret button?????
sjon11
Re: no background
on Jan 28, 2007 at 2:52:04 pm
That's funny...I'm so lonesome I reply to myself the whole time...there's no motionboard I guess...
Anyway, I found out how it works....so no need to reply anymore (probably needless to say....)
grafxflow
Re: no background
on Jan 29, 2007 at 9:54:57 pm
Hi
Try changing the codec settings to animation millions plus. The plus will be your alpha.
I'm not sure how avid will cope with this codec and the alpha!
Hope this helps.
grafx that flow!
