psd file problem - where did my alpha channel go?
COW Forums : Apple Motion
Chris@Horizon
on Jan 16, 2007 at 6:45:03 pm
I've a 2d graphic logo 720x486 saved as a photoshop psd file with a transparent background. I can load it into a FCP timeline and everything appears as it should, however when I import it into motion or livetype, it appears with a white background, the alpha channel is gone. Any ideas why it's there on the fcp timeline but absent in motion and livetype? Thanks!
specialcase
Re: psd file problem - where did my alpha channel go?
on Jan 17, 2007 at 6:29:37 am
Heya,
The alpha channel is still intact: Motion (and maybe LiveType) probably just aren't guessing the proper interpretation. Once you've imported the PSD file into your project, select it and press Shift+F. This will show you the Media tab (in the Inspector) for that particular piece of media. From the Alpha Type popup menu, pick "Premultiplied-White". Photoshop premultiplies alpha with white (which is weird, as most apps premult with black), so this should take care of your problem.
Good luck with your project!
Chris@Horizon
on Jan 18, 2007 at 4:06:30 pm
Yes - Thank-you, that did it in Motion.
