one layer comes out squashed in export
COW Forums : Apple Motion
HHHHDFX
on Jan 1, 2007 at 2:38:21 am
I am animating a clock face. In photoshop, I cut the clock into different layers, a background and one layer for each hand, and then a blank clock layer covering half the clock where the hands had been.
I imported 'All layers' of the PSD file and animated the clock hands in Motion and it worked great, even the RAM preview looks perfect, but every time I export it in compressor, which works perfect 50 times a day other than this, one of the layers, the background, comes out squashed to the left side. I have never touched this layer.
Why is the RAM preview perfect if it is messed up? What causes this?
thanks in advance,
Allan
Peter Wiggins
Re: one layer comes out squashed in export
on Jan 1, 2007 at 11:25:09 am
Have you tried enabling fixed resolution on the layer that contains the item that gets squashed?
Motion handles the rendering slightly different to FCP & Compressor so the above may help.
Peter
