Starstepping while Scaling Graphic
COW Forums : Apple Motion
Tim Martin
on Dec 21, 2006 at 6:50:03 pm
Hi Guys
I have a graphic with alpha channel that I'm scaling from 20 to 60 percent over 3 seconds. The position is also changing slightly (using even numbers). The stairstepping I'm getting is awful. I've tried all the deinterlace/flicker filters as well as gaussian blur/broadcast safe etc filters. I've tried this in FCP as well as Motion.
I'm fairly new to FCP but I'm a long time After Effects/Avid/DPS user...Can anyone tell me what I've missed?
I will cross post...Thanks so much!
Tim Martin
-MacBook Pro - 2.16GHz Intel Core Duo - 2 gig Ram
-FCP Studio 5.1.1 - QT 7.1 - OSX 10.4.6 - Lacie D2 dv external drive - G-raid dv drive
specialcase
Re: Starstepping while Scaling Graphic
on Dec 22, 2006 at 4:26:17 am
Heya,
Did you try setting the anti-aliasing mode to 'Best'? You can find it in the second tab of the Project Properties window (Cmd+J).
Tim Martin
on Dec 22, 2006 at 4:12:53 pm
Hi Special
Definitely have that set...thanks for the reply...
BTW-we have a spirited discussion over on the FCP forum entitled "Re: Stairstepping on Scaled Graphics (Both FCP and Motion)" if you're interested....
Thanks for the reply
Tim Martin
Jim Kanter
on Dec 25, 2006 at 2:15:01 am
Have you tried changing the image size to a smaller one (if you're only going to 60%)?
Small-to-large percentages will alias worse than large-to-larger percentages.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
