Is motion good for 3D animation?
COW Forums : Apple Motion
nelsonmay10
on Nov 16, 2006 at 9:22:49 pm
I am using motion and making 2D to 3D animation. Basically cars moving along a highway for traffic studies. The only problem is, is that I can't draw and am stuck with the angle of the intersection and car I use. Can I import fully 3D rendered cars into motion and manipulate them? The 2D affect is OK, but 3D has more impact. If not motion is there another MAC platform program I can use. Maybe a CAD program? If there is a powerful program that allows you to have intersections and roads that allows you to place cars and pedestrians that would be good.
Thanks in advance.
walter biscardi
Re: Is motion good for 3D animation?
on Nov 16, 2006 at 9:30:26 pm
After Effects works in 3D space. You can place lights and cameras as you need them in the intersections or follow along behind a person or car.
Your 3D objects all need to be in the right perspective though. If you want to actually manipulate the 3D objects themselves, then you need a 3D animation program. In After Effects you can move them and move cameras around them, but you can change the physical object other than distortions.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
Jim Kanter
on Nov 17, 2006 at 2:10:21 am
A good, easy to use and inexpensive Mac 3D app is Carrara basics.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Noah Kadner
on Nov 17, 2006 at 9:01:57 am
I recommend Cinema4D- easy to learn and quite powerful.
Noah
Formosa
A feature film shot on the SDX900
