spin text along vertical axis.
COW Forums : Apple Motion
boohoo
on Nov 16, 2006 at 12:19:36 am
Hi. New to this.
Is it possible to animate text, for example, spin text, along the vertical axis? Are there x y z coordinates like in AfterEffects?
Thanks in advance
Jim Kanter
Re: spin text along vertical axis.
on Nov 16, 2006 at 12:50:25 am
The trick is to scale it on the X-axis only. Keyframe from 100% to -100% and back. Leave the Y axis values alone.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
boohoo
on Nov 16, 2006 at 5:34:45 pm
Thanks for the reply. My apologies if this seems mundane...but how do I tweek the x,y values, can't seem to find these variables. Thanks in advance. Is there a simple tutorial you could lead me to?
Jim Kanter
on Nov 17, 2006 at 2:11:59 am
Select the text object, press the F1 key to open Properties in the Inspector, and twirl open the Scale parameter to see the x and y coordinates and keyframe the x scale separately.
Jim Kanter,
Peter Wikoff
on Nov 18, 2006 at 8:44:50 am
Why not just use the Basic 3D filter in the Distortion section? While still faking 3D it allows you to control XYZ/HBP rotation. It also allows for you to add a back face input.
