Sequence layers?
COW Forums : Apple Motion
Wagster
Sequence layers?
on Nov 2, 2006 at 10:15:09 pm
I have a large number of stills in a layer... about 500. (It's an animatic that I imported from FCP.) I'm trying to set the stills so that they are each a single frame long and sequenced one after the other. I'm nearly there, but I can't figure out how to sequence the layers automatically like you would in After Effects with the "sequence layers" command. Each still would start right after the previous one left off. Is this possible? If not, is there a work around that will yield the same result?
New York-based Editor-Compositor
Jim Kanter
Re: Sequence layers?
on Nov 9, 2006 at 9:44:38 pm
Suggest you do it in FCP by making it a 500 frame sequence the sending it to Motion.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
