Motion does not run on 10.4.8
COW Forums : Apple Motion
Brian Charles
on Oct 16, 2006 at 9:58:02 pm
The computer lab at our school recently updated to 10.4.8 and neither DVD SP 3 nor Motion 1.0 will run. The applications open but do not display all windows, cannot open or create files and de not allow preferences to be set.
All Pro App updates are installed. QT 7.1.3 on generation one G5 Quads 8 GB of RAM. FCP runs fine.
We have trashed prefs, created new users to test, repaired permissions all to no avail.
I'm cross posting to the DVD SP Forum.
Any suggestions?
Winston A. Cely
Re: Motion does not run on 10.4.8
on Oct 16, 2006 at 10:55:17 pm
You didn't get any warnings about hardware incompatibility when you were installing? I know Motion needs monster graphics cards to get going, and you mentioned having a first gen G5 quad.... I would think it's card would be sufficient, but I'm not sure.
Is is possible for you to save all your project files to a disc or external hard drive, and chuck all your Studio Apps, and re-install them all from the ground up? I know it's a pain, but many times, it's worth it.
Is all your RAM Apple certified? I've heard that uncertified RAM can sometimes cause problems, but it seems to me that it would affect the rest of your system, not just 2 apps.
This might not be very helpful. Hopefully someone else will chime in with better tips. Good luck!!!
"If God could do the tricks we can do, He'd be a happy Man." - Peter O'Toole - "The Stuntman"
Machine Model: Power Mac G5
CPU Type: PowerPC G5 (3.0)
Number Of CPUs: 2
CPU Speed: 2.5 GHz
L2 Cache (per CPU): 512 KB
Memory: 4.5 GB
Final Cut Studio (Not Universal, yet)
Brian Charles
on Oct 16, 2006 at 11:49:46 pm
Thanks for the reply.
The machines were all running Motion and DVDSP prior to ugrading to 10.4.8.
All Apple RAM and 6800 256MB video card. These are very capable systems.
specialcase
on Oct 17, 2006 at 5:33:07 am
Heya,
If some windows are missing, then system's version of ProKit (the Pro Apps' UI framework) may be borked or otherwise incompatible. Try running the Pro Application Support updater found here: http://www.apple.com/support/downloads/proapplicationsupport31macosx104.htm...
It can't hurt, and it may do the trick (PPC only, I believe).
Good luck!
Brian Charles
Re: Motion does not run on 10.4.8 Thanks
on Oct 17, 2006 at 2:17:47 pm
We'l give this a try. Thanks for your response. Will keep you posted.
Noah Kadner
on Oct 17, 2006 at 4:14:54 pm
Also- an upgrade to FCP Studio with Motion 2 and DVDSP 4 would be highly advisable and relatively inexpensive. I kinda doubt Motion 1 and DVDSP 3 are being tested all that much with each new build of OS X as they are both several years old now.
http://www.apple.com/universal/crossgrade/
-Noah
JIm Kanter
on Oct 17, 2006 at 4:57:21 pm
Not to mention the additional tools and improved stability of M2...
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Brian Charles
Re: Motion does not run on 10.4.8, Now working thanks to specialcase
on Oct 17, 2006 at 5:03:13 pm
Done. specialcase's suggestion worked.
Thank you for your help.
An upgrade to the lab (50 seats) is currently not in the budget.
