Seasons Template - Leaves Particle Emitter
COW Forums : Apple Motion
Sam
by
on Oct 5, 2006 at 3:21:18 am
Hi
I was trying to create leaves flying off the screen and decided to load the Seasons Template to see how it was done. I noticed that the particle emitter just says "leaves".
I couldn't figure out what particle emitter was used to create the leaves fall down the screen.
If I were to create a Wipe transition where a bunch of leaves fly across the screen from left to right, how could I acheive that effect?
I am assuming that the "leaves" particle is somewhere on my hard drive as well?
Thanks for your help
Sam
Winston A. Cely
Re: Seasons Template - Leaves Particle Emitter
on Oct 5, 2006 at 6:07:19 pm
Try this out: http://www.motionsmarts.com/tutorials.html
It's probably a combination of the faking collision, and particles tutorials that will get you on your way to what you want.
"If God could do the tricks we can do, He'd be a happy Man." - Peter O'Toole - "The Stuntman"
Machine Model: Power Mac G5
CPU Type: PowerPC G5 (3.0)
Number Of CPUs: 2
CPU Speed: 2.5 GHz
L2 Cache (per CPU): 512 KB
Memory: 4.5 GB
Final Cut Studio (Not Universal, yet)
