Motion 2 crashing
COW Forums : Apple Motion
Bill Parker
Motion 2 crashing
on Sep 14, 2006 at 8:24:55 pm
I've been using Motion 2 in HD720p and am experiencing multiple crashes. I mostly use the application for photos. I trashed the perferences and crossgraded to FCP Studio 5.1 to no avail. Can anyone suggest something else to fix the problem?
I use a G5 w/ 4GB of RAM.
Thanks.
Jerry Hofmann
Re: Motion 2 crashing
on Sep 30, 2006 at 11:58:59 am
It's really stable here... so I'd suggest a clean install of a new startup disk... Sounds a bit like the "sledge hammer" approach, but I really believe this should be done periodically... at least every time a new OS is installed... not updates, but upgrades you pay for...
Jerry
Apple Certified Trainer
Author: "Jerry Hofmann on Final Cut Pro 4" Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Lance Drake
on Oct 2, 2006 at 8:41:08 pm
Motion has taken the (unfortunate) step of performing lots of their magic in the MacOSX KERNEL memory-space under the auspices of a kernel process.
When something bad happens - like a memory resource error - not only does Motion crash - but it takes down the whole system.
Whereas, when an app and it's resources are all located in USER space - then when something bad happens, there's hope to recover - or, failing that, the app can crash - but NOT the whole system which is what happens with Motion.
This approach they've taken is really a sad situation and, unless they get out of KERNEL space and not do all their work in a kernel-process, this kind of nonsense is going to keep being a part of the Motion experience.
FWIW - The times I most often run into trouble are when I have something going on that uses almost all of the system RAM - and that's not hard to do - or when I am rapidly clicking around from viewing-area to viewing-area and it seems to get behind and lost in the updates.
HTH
