Freeze Frame, Pause in motion
COW Forums : Apple Motion
Smoothe271
on Aug 18, 2006 at 7:20:25 pm
Is there a way you can put a freeze frame from the video in motion. Or do I have to export an image every single time on Final Cut to work with it.
Adolfo Rozenfeld
Re: Freeze Frame, Pause in motion
on Aug 21, 2006 at 2:25:52 am
You can easily do this in Motion. Select the Object and then go to the Media tab in the Project palette (Hit Command-4 or the "Project" button if not already visible). Select the thumbnail related to your image (again, in the Media tab, not the Layers tab) and then go to the Inspector. It will show the different interpretation and timing behaviors of your source footage. Set the Start and End frames to the frame you want and then set the End Condition to "Hold". You can now alter the duration manually in the timeline for your frozen image.
Adolfo Rozenfeld
Buenos Aires - Argentina
http://www.adolforozenfeld.com
adolfo(AT)adolforozenfeld.com
