Motion won't open properly
COW Forums : Apple Motion
Mike_P
on Jul 12, 2006 at 4:07:35 pm
When I try to open a template or create a new project the canvas window does not open. I only get a library and navigation window. When I try to check my prefs, they won't open. I trashed my old prefs, and even reinstalled Motion and still no luck. Has anyone else experienced something similar? Is there a trick to uninstalling? I trashed the app, the prefs and reciept files, then reinstalled.
I'm running FCP 5.0.1 on a Quad 2.5 G5, 4 gigs RAM, OSX 10.4.7, Blackmagic Decklink card.
specialcase
Re: Motion won't open properly
on Jul 13, 2006 at 3:37:58 am
Heya,
It's possible that your ProKit version (the Pro Apps UI library) has gotten mismatched. That's usually the reason for windows not appearing/drawing.
Try downloading the Pro Application Support update from http://www.apple.com/support/downloads/proapplicationsupport31macosx104.htm...
It may do the trick. Good luck!
Mike_P
on Jul 18, 2006 at 2:41:19 pm
Hurray! It worked. It also fixed a weird crash problem I was having with Batch Monitor. Thank you.
