Best way to create presized Drag & Drop Template
COW Forums : Apple Motion
Sebastian
on Jun 26, 2006 at 8:24:59 pm
I would look to create a Template where I have photos that will be dropped into precreated "replace" areas and once imported, they will automatically be resized at a predetermined size I have chosen. I also want to preset all alignemnts: align top, distribute space horizontally. I am looking for the best way to create a drag & drop Template. I will make sure all images are the same size before importing them into Motion 2, if this helps.
As alwways thank you for reading and reply to my post,
Sebastian
Mark Spencer
Re: Best way to create presized Drag & Drop Template
on Jun 27, 2006 at 10:44:36 pm
Just go ahead and make your template with a set of media that will be the same size as your replacement pieces, then save it as a template. Pretty straightforward.
Mark Spencer
Freelance Editor/Producer
Apple-certified instructor, FCP, DVDSP and Motion
Author, Motion Visual Quickstart Guide from Peachpit Press
http://www.applemotion.net
