Project settings and fileds
COW Forums : Apple Motion
lapotnik
on May 18, 2006 at 3:51:01 pm
I am looking for the best project settings to work in Motion - FCP or AVID environment. Specifically the field (upper/lower) settings for the canvas-project and then the final export rendering settings. In the project as you create animations it seems it is better to use "no fields" option so you can see objects in non-jagged appearance.
When I rendered the final version for DV-FCP I've used lower field first and no fields settings. So far I didn't notice any difference. But it mine so far limited experience with Motion. If anybody got any recommendations on field no field settings and correct aspect ratios for DV/AVID workflow I would appreciate.
Victor
Noah Kadner
Re: Project settings and fileds
on May 18, 2006 at 5:51:46 pm
Stick with the DV or lossless presets and you'll be fine.
Noah
