motion text output low quality?
COW Forums : Apple Motion
shaun Au
on May 1, 2006 at 4:20:05 pm
Hi, I created this title with Motion. However, the text in the final output looks very fuzzy. When I play it in Motion timeline, everything looks sharp and smooth. What's going on? Thanks!
Noah Kadner
Re: motion text output low quality?
on May 2, 2006 at 5:27:33 pm
What are your export settings? And where are you judging the final quality?
Noah
shaun Au
on May 2, 2006 at 5:55:22 pm
I found out what's wrong with it. It's the export setting. If I use "Lossless+alpha", the text comes out sharp and smooth. I was using NTSC DV which is a compressed format. Thanks!
