"Send to Motion" from FCP give Low-res Footage
COW Forums : Apple Motion
Erik Lindahl
on Apr 11, 2006 at 1:26:06 pm
Sorry if this is concidered a double post, but it really is a Final Cut AND/OR Motion issue
specialcase
Re: "Send to Motion" from FCP give Low-res Footage
on Apr 11, 2006 at 5:08:34 pm
Hey Erik,
When FCP sends the footage to Motion, it creates a Motion project with the footage already imported. I would hazard that FCP is not properly setting the Alpha Type for the clip, in the Motion project. But when you import it into Motion, yourself, Motion has the opportunity to detect/guess the alpha, and sets it correctly.
If it seems like the alpha is gone, just select the clip (in Motion) and press Shift+F, which will take you to the Media settings for that footage. Check the Alpha Type popup menu (first item) in the Media tab of the Inspector, and see if making a change fixes your problem.
Hope this helps. Good luck!
Erik Lindahl
on Apr 11, 2006 at 9:56:29 pm
Got ya
Erik Lindahl
on Apr 12, 2006 at 8:53:29 am
Okej. The problem is the same as with After Effects. I have to set the footage field-domninace to NONE or it gets 50% lower resolution. Irritating, but it works.
Now I noticed that Motion won't respect filters but on clips in Final Cut. This REALLY sucks I must say since Final Cut has the three-way color corrector and motion doesn't
Greg Niles
on Apr 12, 2006 at 9:35:17 pm
[Erik Lindahl] "Got ya
Erik Lindahl
on Apr 13, 2006 at 8:12:29 am
Well, perhaps
