Finding A Frame In A Image Sequence?
COW Forums : Apple Motion
Martin Reuben
on Feb 13, 2006 at 10:17:17 pm
I have a 1425 frame image sequence imported into Motion. I need to identify several of the still frames in this sequence in order to do some additional effects on those frames. Is there any easy way to positively identify a single frame in a sequence when you click on it on the time line?
Martin Reuben
http://www.trgstudios.com
Peter Wiggins
Re: Finding A Frame In A Image Sequence?
on Feb 13, 2006 at 10:33:49 pm
A quick & dirty way would be to toggle the image sequence button off which would then show every frame in the browser.
Blow the size up so you get a large frame then scroll through until you hit the frame you need.
Make note of the numer/s and then go down the timeline to that frame.
Having said that there is probably an easier way;)
Peter
Free Motion Templates
http://www.peterwiggins.com
Martin Reuben
on Feb 13, 2006 at 10:39:14 pm
[Peter Wiggins] "image sequence button"
button?
Martin Reuben
Peter Wiggins
on Feb 13, 2006 at 10:42:49 pm
Its on the bottom of the browser, looks like a lot of cards stacked up in 3D
Toggle that and it will switch from showing all the frames to one just file.
Peter
Oh for image sequence support in the OS!
Martin Reuben
on Feb 13, 2006 at 10:47:17 pm
Got it, thanks!
(And right - there has to be an easier way!)
Martin
Martin Reuben
Greg Niles
on Feb 14, 2006 at 4:30:47 pm
Go into preferences, click on the Appearance icon. Change the Timebar Display popup to "Filmstrip". Now, if you zoom into the timeline, you should see a thumbnail for all frames in your image sequence.
Peter Wiggins
on Feb 14, 2006 at 5:40:31 pm
Greg,
As always, many thanks ;)
Peter
