Changing from DV to Hd Workflow
COW Forums : Apple Motion
JimR
by
on Feb 3, 2006 at 3:55:07 pm
Made Titles in Pal DV for offline, Now must supply these title animations in HD or Uncompressed DigiBeta onlines.
what is the easiest workflow to convert in motion and keep same size relationship
if I copy and paste from SD To HD Then I have to Resize by Eye must be an easier way.
Also do I export as Quicktime Lossless+ alpha for Best Quality.
Thanx
JimR
Noah Kadner
Re: Changing from DV to Hd Workflow
on Feb 3, 2006 at 4:10:36 pm
That's about it- totally different resolution, framing and frame rate so there's no automatic way if you want it to look rate.
Noah
JimR
by
on Feb 3, 2006 at 8:17:37 pm
Thanx for feed back.
