Easy answer eludes me
COW Forums : Apple Motion
David
on Feb 1, 2006 at 2:41:31 am
I've created a motion path that my elements follow. (Its a rectangle) I want the elements to continue to follow the motion path indefintely. Looping playback isn't quite right of course. I'm sure the answer is out there I just can't seem to find it. Perhaps though, I didn't "close" my rectangle although I'm pretty sure I did.
Any help would be appreciated
David
Bill McGuire
Re: Easy answer eludes me
on Feb 1, 2006 at 2:56:10 am
there is probably a much easier way, but you could save as QT and replace it with that...
Jim Kanter
on Feb 3, 2006 at 8:47:27 pm
Did you use the motion path behavior or keyframes to animate the object's position?
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Mark Spencer
on Feb 3, 2006 at 9:57:35 pm
Following up on Jim's question, if you keyframed the motion path, you could go to the keyframe editor and choose "after last keyframe" to repeat the animation ad infinitum from the animation pulldown menu.
Mark
Mark Spencer
Freelance Editor/Producer
Apple-certified instructor, Final Cut Pro and Motion
Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
http://www.applemotion.net
