Speed Change
COW Forums : Apple Motion
matzunaga
Speed Change
on Jan 26, 2006 at 5:33:23 pm
Hi to all
Can someone please tell me how do I chage the speed of an object? In after effects I just change the duration and it slows down the footage. How do I do it in Motion?
Matzunaga
Arniepix
Re: Speed Change
on Jan 26, 2006 at 7:28:58 pm
It's a little counter-intuitive. OK, it's a lot counter intuitive!
In the timeline, right click (option click if you have a 1 button mouse) on the object & select "Reveal Source Media". this will open a new window out from under your canvas that shows all of the media files that are in the timeline. Select the one you want to change the speed of, then change the speed in the inspector.
Arnie
http://www.arniepix.com
matzunaga
It just wont change
on Jan 26, 2006 at 8:24:18 pm
I have been to the media tab in the inspector and it just wont work, tried different FPS it just wont work. Does it mean that I have to go back to AE?
Matzunaga
Mark Spencer
Re: It just wont change
on Jan 27, 2006 at 1:17:38 am
Changing the Frame Rate parameter in the Media tab of the inspector should certainly work, but you can also try keyframing the Scrub filter - not intuitive either, but works pretty well.
Mark
Mark Spencer
Freelance Editor/Producer
Apple-certified instructor, Final Cut Pro and Motion
Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
http://www.applemotion.net
Mark Spencer
Speed change article
on Jan 30, 2006 at 9:03:22 pm
Here, read this:
http://www.kenstone.net/fcp_homepage/speed_changes_motion.html
Mark
matzunaga
Re: Speed change article
on Feb 1, 2006 at 8:06:56 pm
That tutorial is just what I needed. For some reaseon, changing the fps in the media tab is not working for me but I did try the scrub and it worked great.
Matzunaga
