Apply a stroke to an animated alpha? NEED HELP!
COW Forums : Apple Motion
Pippin
on Jan 5, 2006 at 9:29:59 pm
Hi all,
I am trying to put a stroke around an actor that has an alpha all ready applied to him. I know that in Photoshop I would just select the alpha, and create a shape from the selection.
Now the important part is that I need the stroke to follow the actor as the spot plays out... Any ideas, or are there any plug-ins I might purchase to help facilitate this action?
specialcase
Re: Apply a stroke to an animated alpha? NEED HELP!
on Jan 5, 2006 at 11:28:09 pm
Heya,
You can use the Outer Glow filter. Just clamp it down so that the glow is a hard line, then pick your thickness and colors.
Hope this helps. Good luck!
Jim Kanter
on Jan 6, 2006 at 5:04:16 am
And if that doesn't work, export a movie file of the alpha channe onlyl.
Import the movie, place it under the actor element and scale it up slightly.
Color to suit.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
