Motion keeps crashing.Please HELP!
COW Forums : Apple Motion
alex quintanar
on Dec 5, 2005 at 5:48:35 am
I've been running Motion 2.0.1 and it keeps crashing on me. I checked some of the previous threads and posts and I seem to be getting the same crash report, but the difference is that I don't have a Blackmagic or AJA link. Motion is stable and doesn't crash when I disconnect the CRT Phillips 20" TV that I have hooked up to the second port on the ATI Radeon 9650 (DVI->S Video adapter). I'm using a dual 2.7 with 2.5 Gb of RAM. I'm still just learning how to use Motion with the tutorials so I don't think I'm pushing the program that hard. Motion will launch and I can open up a project with the 2nd display on for monitoring but the second I toggle to another application like Safari or Itunes it goes down and gives me this crash report:
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
Do I need more RAM or could it be the video card?
Any suggestions. (BTW I cleaned up Font Book and that didn't seem to help at all)
Alex Quintanar
"To be or not to be. What was the question?
Noah Kadner
Re: Motion keeps crashing.Please HELP!
on Dec 5, 2005 at 6:35:23 pm
Trash prefs and the like- and then try a reinstall and Software Update.
Noah
waterboy
on Dec 11, 2005 at 4:46:18 am
life is so uncertain...
OK, i've done all of what was mentioned earlier in this thread, minus the second monitor deal and motion is still crashing. i do not have a decklink card so that's not the deal, any ideas?
e. eric johnson iii
eric@lillcreates.com
lill creates: founder/executive producer
Water Channel: producer/virtual set operator+?
Jim Kanter
on Dec 12, 2005 at 3:32:20 am
Did you have Motion 1 installed at any time?
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
WaterBoy
on Dec 12, 2005 at 4:41:25 pm
yes, and i blew it out prior to loading motion 2. this seems to have happened after the update. i hadn't had any projects requiring motion for awhile, then #*^%#$@@!!!!
so, i re-reinstalled motion 2 and it works better; however, it still crashes or is sluggish at best.
e. eric johnson iii
Jim Kanter
on Dec 12, 2005 at 5:12:19 pm
Try this:
http://docs.info.apple.com/article.html?artnum=302596
Jim Kanter,
WaterBoy
on Dec 12, 2005 at 6:28:35 pm
thank you jim... i'll give 'em a try and post with the results. thank you for the time and input. glory to the cow!
e. eric johnson iii
