another newbie question
COW Forums : Apple Motion
Brian Pitt
on Nov 16, 2005 at 4:49:10 pm
i am working on a DV NTSC project and it keeps giving me an error messge that says: "This object is too large to render, and will be cropped. The maximum size is 2048 by 2048."
I am working in a 720 by 480 workspace, so that doesn't make sense. Anybody know how to fix this?
Brian
Arniepix
Re: another newbie question
on Nov 16, 2005 at 6:23:23 pm
One of your source files, or perhaps a layer, is bigger than that 2k size. Are you working with stills? Or, perhaps, you're using particles? Once you identify the culprit layer, you can make that layer 'fixed resolution' in the inspector. I think there was a tutorial specifically about setting layers to fixed resolution here on the cow a couple of months ago. It explains the issue rather well.
Arnie
http://www.arniepix.com
Noah Kadner
on Nov 16, 2005 at 6:34:17 pm
As a newbie you probably don't know but it's considered polite to respond to follow up questions that arise from your initial post before starting another...
