Motion Crashing in 10.4.3
COW Forums : Apple Motion
Graeme Nattress
on Nov 4, 2005 at 11:58:07 pm
The problem is caused by installing 10.4.3, regardless of whether you are running Motion 2.0 or 2.01, if you have a Decklink card set to "Video Desktop" On.
The temporary solution is to turn off video desktop on you Decklink card. Apple will fix the problem in the OS in a future OS X release and are fully aware of the problem. Indeed, they've been working very hard since I pointed it out to them to come to a solution, and I must add that the cooperation of those on this forum has been excellent in finding a solution.
I'm now back up and running in Motion, and can finish my current project.
Graeme
- http://www.nattress.com - Film Effects and Standards Conversion for FCP
Kim Rowley
Re: Motion Crashing in 10.4.3
on Nov 5, 2005 at 3:19:50 pm
So the problem with this Motion update only affects those with the decklink card?
I got scared after reading your posts and haven't made the plunge. Any problems with the AJA I/O?
Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20" Cinema Display, FCP 5.02, OS X10.4.2
Graeme Nattress
on Nov 5, 2005 at 4:56:17 pm
The IO doesn't have a video desktop feature, so should not be effected in any way.
Graeme
Kim Rowley
on Nov 5, 2005 at 5:06:48 pm
Thanks Graeme. I'll go ahead and update.
Adolfo Rozenfeld
on Nov 5, 2005 at 11:02:07 pm
Thanks for the information, Graeme!
It's important to note that this doesn't just solve the problems I was having with Motion, but it also solves a nasty behavior in After Effects, where OpenGL previews of 3D shadows gave an error message. In case it helps...
I am back to speed with both Motion and AE :) I thought it was going to take weeks to solve this!
All the best,
Adolfo
Adolfo Rozenfeld
Buenos Aires - Argentina
http://www.adolforozenfeld.com
adolfo@adolforozenfeld.com
Dan Brazil
on Nov 6, 2005 at 12:27:48 pm
Yes, I think there is fundamentally something that disagrees with having the Blackmagic video desktop set to 'on' and the smooth running of the G5. Interestingly this is a solution that helped me to resolve another issue which I posted on the Blackmagic forum earlier on this week.
http://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=...
A bit of pain, but atleast there's a temporary workaround. Hope it gets resolved soon.
Lu Nelson
on Nov 17, 2005 at 4:25:22 pm
-- do you find this is applicable to the Blackmagic SD cards as well? I have a DL Extreme and have noticed some crashing...however it seems from the other posts that maybe it's just the HD cards?
