time changes
COW Forums : Apple Motion
heidi Phillips
time changes
on Nov 4, 2005 at 6:07:44 pm
I have been learning motion for the past little while. I have yet to find how to make speed changes to imported video. Is this possilbe in Motion?
heidi
Adolfo Rozenfeld
Re: time changes
on Nov 6, 2005 at 6:06:01 pm
By speed changes, you mean slow/fast motion or variable speed? If it's the first thing, you just have to go to the media tab in the inspector (select the object and hit Shift-F) and change the Frame Rate setting.
For simple time remapping, you have the scrub filter (Add Filter > Time > Scrub). The frame offset parameter allows you to control a virtual playhead.
Hope this helps.
Adolfo Rozenfeld
Buenos Aires - Argentina
http://www.adolforozenfeld.com
adolfo@adolforozenfeld.com
