lost particle emitters,, replicaors, shapes, gradients from library
COW Forums : Apple Motion
Barbara Johnson
on Oct 29, 2005 at 2:08:55 pm
In a dazed 2 AM mind, I did something that affected the path, and now in the library, all the other goodies are there, but not those listed above. I can find the ones i have looked for in the hard drive, but dont know how i coud use them within motion. should i uninstal and reinstall Motion, or is there a way to get these goodies in order.
Thank you, thank you
Barbara
Jim Kanter
Re: lost particle emitters,, replicaors, shapes, gradients from library
on Oct 29, 2005 at 2:51:58 pm
Library folder path is set in the application Preferences.
Make sure everything is in there and then point Motion at the main folder. The default is under USERS > SHARED > MOTION > LIBRARY on the main system drive.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Barbara Johnson
on Nov 1, 2005 at 4:06:23 am
Thank you, thank you. I should never play with my computer in the middle of the night...I should never.....
Thanks again
Barbara
