1920x1080 filter error
COW Forums : Apple Motion
Donavan
on Oct 24, 2005 at 6:47:57 pm
I'm trying to create an image for HD (1920x1080) and when applying the final effect (both dazzle and light rays)I get an error that:
"This filter has been applied to an object too large to render, the output will be cropped. The maximum size is 2048x2048"
The result of this is everything in that layer then shifts and gets badly altered. I've tried checking the 'Fixed Resolution' in the layer tab in the inspector and it did nothing to get past this problem. Am I missing something?
Thanks.
specialcase
Re: 1920x1080 filter error
on Oct 24, 2005 at 8:33:09 pm
Hey Donovan,
After you enabled Fixed Resolution for the parent layer, did you move the filters from the clip to the layer? If not, the order of operations means that the filters still process on the larger image (resulting in hitting the max texture limit and getting cropped) before the layer gets cropped in Fixed Resolution.
For a more complete explanation, check out http://homepage.mac.com/specialcase/articles/sizematters.html
Donavan
on Oct 24, 2005 at 8:47:23 pm
Thank you, that does indeed seem to fix the problem. Thanks also for the link, very useful info!
