Getting rid of Bounding Box Problems
COW Forums : Apple Motion
Mark Jackson
on Oct 19, 2005 at 9:57:24 pm
I'm trying to add a filter to a title I made in Motion. The problem is the rays of my effects is trapped in this bounding boxing. How do I get rid of the bounding box?
Mark
specialcase
Re: Getting rid of Bounding Box Problems
on Oct 19, 2005 at 10:52:19 pm
Hey Mark,
if it's Light Rays that you're running, then try adjust the Expansion setting. If that doesn't do the trick, nest the object in a layer, turn on Fixed Resolution for the layer (found in the Layer tab of the Inspector) and apply the filter to the layer. Basically, a pre-comp :)
Good luck!
