work flow from motion 2k project to Cinema 35mm upload
COW Forums : Apple Motion
Mohamed Mira
on Oct 3, 2005 at 6:03:27 pm
Hi all
I'm a new to motion2
My concern is that i need to find a work flow to produce 2k film intro in motion2 then upload it to a 35mm reel.
will any one help me, even theorically and i'll try that my self and post the results later
lookin for yr advice soooooooooooooon
best regards
Mohamed Mira
Jim Kanter
Re: work flow from motion 2k project to Cinema 35mm upload
on Oct 3, 2005 at 9:35:30 pm
Would this be all-original graphics, or would you want to import and use video clips?
You would need to work at the 2K frame size in 32-bit float color space. You will need to have the biggest, baddest dual-G5 with high-end video card and lots of RAM to work reasonably at those specs.
For outputting you would check with the filmout service bureau as to the best file format for them to work with.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Mohamed Mira
on Oct 4, 2005 at 5:55:41 am
Dear Kanter,
I guess it will be all original graphics.
But, what if I may import some video clips? Any rolls to follow
Could I have a very small info about file format that could be transferred to film, Or a web link with that info.
Thanks a lot for yr advice
Best regards
