Multiple clips into multiple files
COW Forums : Adobe Audition
Mike Bernard
on Jul 4, 2018 at 1:38:27 am
I have 40 or 50 individual clips that I need to edit a bit ( taking out pauses and false takes ) and then master ( they are all from the same voiceover session ) and then export as individual clips. I'm thinking of making a multitrack session,, working on each clip, having them all run through the same master effects and then just soloing each track and exporting them one at a time. Any of you bright cats see a more efficient method through this ?
Mike
Kalleheikki Kannisto
Re: Multiple clips into multiple files
on Jul 4, 2018 at 7:46:26 am
I don't know how if it is much better than your approach, but you can make the effect settings you want in the first track, save as preset and then assign them to each track. You can then export multitrack as individual tracks upon export in one go. I would try with a couple of tracks first to see if there's anything to be gained that way.
Senior Graphic Designer
