Bad Audio Track, but is it repairable?
COW Forums : Adobe Audition
Tracy Peterson
on Oct 15, 2017 at 2:52:50 am
Thanks for looking. I just recorded a live event and we didn't have good backups running and the main was damaged. It was one of those things where software seems to have introduced an issue down the line from monitoring (so yes it was a bad monitoring job as well). The problem seems to be related to dropped frames upstream of the video source. That said, it's a very consistently timed modulation of the audio. Like every few millisecond or so there's a bit of judder or dropout. That's the best I can manage to describe it. I'll add a small clip shortly once I've had a chance to look at it.
I guess I'm going to see if I can make some kind of fix for it in audition using my limited skills, but my real question is if i can automate any fixes so that they go across the entire two hours without manual labor?
11762_capture0004audioextracted01.pkf.zip
Take a look and if there's any advice out there, I'm happy to try anything!
Best,
T
Tracy Peterson
http://www.theavsociety.com
