Sample Rates and Bit Depth
COW Forums : Adobe Audition
Jennifer Keller
on Oct 15, 2014 at 8:37:21 pm
I am trying to troubleshoot a problem in a multitrack session of Audition. The length of the file seems to change after exporting the session and the markers are all out of place when I bring it into After Effects.
> Started with 2 - 32 bit, 480000 Hz files (worked fine upon export)
> Added 5 - 16 bit, 414000 Hz files (time and markers are off after adding these)
Is there a customary practice, when combining bit depths or sample rates? I am wondering if I am doing something wrong in this area?
Chris Wright
Re: Sample Rates and Bit Depth
on Oct 20, 2014 at 12:33:27 am
did you try save as edit-convert sample to all match and edit-interpret each?
