Recording straight into Adobe Audition CC
COW Forums : Adobe Audition
Mp Nunan
on Mar 9, 2014 at 1:16:11 am
Hello -- I have both Adobe Audition CS6 and Creative Cloud.
It used to be, on my Windows computer, I could simultaneously record from a line-out or headphones out on a camera, or audio-recorder, into the line-in on a laptop straight into Adobe Audition (then called "Final Edit") in real-time.
My MacBook Pro is from 2013. (The bottom computer in this pic.)
NOW, my Adobe Audition doesn't want to record from a line-in / mic-in jack. If it does, it's very, very low levels.
Yes, I have the "System Preferences" under Sound set to "line in" and "audio-line in port."
Where can I adjust levels?
Am I missing a setting somewhere?
Thank you in advance. - MP
Joseph W. Bourke
Re: Recording straight into Adobe Audition CC
on Mar 13, 2014 at 1:35:43 pm
You don't say anything about the sound card in your MacBook Pro, so I would assume that they use an onboard card, but there should be some sort of control panel for levels going in to and out of the card.
A microphone input is typically a very low level signal, and is mono. A line in will be expecting a much higher input level, and will usually be stereo.
The sound card should have an additional pre-amp stage for the mic to bring it up to line levels. Here's a rundown on the internal card (probably Intel):
Can you adjust the input levels on the device outside the MB which is sending the audio?
Joe Bourke
Owner/Creative Director
Bourke Media
Mp Nunan
on Mar 13, 2014 at 5:04:13 pm
Thank you for the reply.
Messing around with this some more, I'm able to record a mono recording from a line-out with my Ipod, for example (clearly this is not a sound-card issue.)
However, I'm unable to monitor the audio through my computer's headphones out at the same time (bearing in mind that I have a separate line-in.)
Any idea?
© 2018 All Rights Reserved
